Multisim Custom Simulation Analyses and Instruments Documents
Sawtooth Waveform Generator
Name
Sawtooth Signal
Included
LabVIEW Custom Instrument, Test Circuit
Compatibility
Multisim 11.x, Multisim 12.x
Description
     The sawtooth wave is one of the most commonly used signal in electronic circuits, of which one of the most useful applications it can aid is in the triggering of signal oscilloscopes. Paired up with the triangular wave you can have a combination of sounds very useful for audio application analysies and create thousands of sounds and harmonics for music synthesizers. You can find the Triangle Signal VI of the same design under the Triangle Waveform Generator document.
Instrument for Multisim 11 and 12.0 download
Instrument for Multisim 12.0.1 download
Test Circuit
     The circuit here can be paired with that of the Triangle Signal VI from another document. Simply replace the Function generator with the appropriate VI to get much more complex sounds.
Contributors
