Name
Nyquist Plot
Included
LabVIEW Custom Instrument, Test Circuit
Compatibility
Multisim 11.x, Multisim 12.x
Description
By definition, a Nyquist plot is a cartesian coordinate representation of the transfer function of a system that includes a closed-loop feed-back. From the Nyquist plots, designers can evaluate important circuit attributes, such as stability regions and the number and locations of poles and zeros. Nyquist plots are very useful for filter and amplifier circuits used in signal processing and control applications. An example is provided that uses the instrument of the noise generator to provide a white noise signal as an input to a chain of 3 bandpass, lowpass, and highpass filters.
Instrument for Multisim 11 and 12.0 download
Instrument for Multisim 12.0.1 download
Test Circuit
Note: The following test circuit requires the use of another custom VI that can be found under the signal generator category. It creates a noisy signal to be analyzed.
