Multisim Custom Simulation Analyses and Instruments Documents
Noise Source Generator
Name
Noise Source
Included
LabVIEW Custom Instrument
Compatibility
Multisim 11.x, Multisim 12.x
Description
     In electronics, noise is defined as an undesired electrical signal. While noise is considered undesirable in many cases, noise actually can be useful and allow you to characterize systems. Because white random noise has an inherently flat frequency spectrum, you can use white random noise to characterize the frequency response of systems such as filters. You also can use artificially created noise to characterize systems. Artificially created noise often is based on random number generators created with an algorithm whose output repeats only after a significantly large number of samples. Each output sample is approximately statistically independent. The algorithms used to generate random numbers often are based on a seed value that specifies the starting point of the algorithm. Modern random number generators can produce sequences that repeat only after 2^(19937)-1 samples. This generator is a simple tool to help you visualize and analyze a circuit with a noisy input signal. It'll let you select the filter specification that you want with a low or high cutoff frequency, the type of noise you want to use, the order, density, and standard deviation, among many other options (read this article for more background information on different noise signals).
Instrument for Multisim 11 and 12 download
Miguel V
Comments
昏君HL
Member
Member
on
How to install the instrument?
Fernando_D
Active Participant
Active Participant
on
In the main page (Multisim Custom Simulation Analysis and Instruments), there you'll find instructions and also a video on how to install these instruments.
Regards,Fernando
Fernando D.
昏君HL
Member
Member
on
thank you very much!
SilasIII
Member
Member
on
I still can not find out any link teaches how to install them on Multisim! Would you please provide me any help or link? Thank you
Mcdl
Member
Member
on
ok, so i can't install at all the instrument. I follow every step E V E R Y S T E P, ans still nothing.
Please help.
Contributors
