Multifunction DAQ
wiring NI 6238 to pressure transducse
Hi everyone
I have a PT5 pressure transducer which has two wires with one for 24Vdc power supply (brown wire) and the other for 4-20mA ouput (white wire) like in the link below
http://www.emersonclimate.com/Documents/FlowControls/pdf/eevc/isheets/PA-00329%20-%20PT5.pdf
I am confused about wiring this pressure transducer to NI 6238. I try to connect its brown wire to power supply (+) and white wire to AI0+ (no 1) of the NI 6238. The power supply (-) then is wired to AI GND (no 3) of the NI 6238 in order to create a electrial loop. Is that correct connection?
Greatly appreciate your help!
(2,861 Views)
@333333 wrote:
Hi everyone
connect brown wire to 24vdc power supply, connect white wire to AI0+(pin1) of daq, connect return wire to AI0- (pin20) to Daq AI GND and to GND of 24vdc power supply...according to method 2 of the 6238 manual 4-4
(2,846 Views)
