Multifunction DAQ
why i m geting fault LAB View- Memeory is full
We have developed an Steering Testing application in LabVIEW 7.1.
It is installed On Site and was running .
But now there is one problem in this application.
In this application we have Sub VI named "Scaled Rotation Array. Vi", which accepts 2D array of 500 values . From each element of array , we subtract one Constant value and forms the result array. This result array is used for Graph
We are gettingFault  as " LAB View- Memeory is full" and " Vi RBS _PTM.Vi" was stopped at node Ox 518 of Sub Vi    " Scaled Rotation Array. Vi"
Can anyone help??Smiley Indifferent
(2,941 Views)
Would you post your code??
especially that sub VI you mention, so that we can suggest better
(2,938 Views)
Also, post this query in LabVIEW discussion board.
It would be more relevant in that board
Charnces are that more LabVIEW users will look at it
(2,936 Views)
