Multifunction DAQ
which card ???
hello, I seek the best adapted card to acquire these signals:
INPUT :
1. a frequency of 0 A 20 Hz (tachometer).
2. a tension of 0 A 30 mV (load cell).
OUTPUT :
1. 2 tension of 9 V (if it is possible since it is the food of the 2 sensor).
2. an outpout to a frequency converter?????,,.
thank you.
softus
(2,830 Views)
Softus,
We offer many devices that will fit the applications you have mentioned. The speed and resolution you want are also things to take into consideration when purchasing a Multifunction DAQ device. The M Series data acquisition devices are most likely the best fit for you. Check them out here. You can call (800) 531-5066 for assistance in selecting devices.
Michael P
(2,810 Views)
