Multifunction DAQ
what is the interface between the DAQ and the device to trigger?
Hello there,
i would like to trigger an electric valve with 12 volt and 20mA, on and off using DAQ PCI-6036E, I would like to know what add in between the card and the valve to acheive this power.
any sugession will be highly appreciated.
Aneece
(3,328 Views)
http://www.rentron.com/images/NPN-DRIVER1.GIF is one of the idea.
Use 6036 digital output to drive the circuit.
(3,307 Views)
Hi KateB,
thanks for your reply, from NI SCC-68 I use the digital output, can I know how much the range of the voltage and electric current can be generated from this card through SCC-68?
(3,305 Views)
(3,303 Views)
