Multifunction DAQ
waveform array
Dear All,
I would like to transform a data array into a waveform using LabWIndows/CVI.
I tried to use the function _CreateArbWaveform but I didn’t succeed; I got a compile error “Missing prototype” (Function declaration or call is for a function without prototype declaration information). Does anybody know how to convert a data array into a waveform?
Thank you very much for your help.
Martiemp.
(3,290 Views)
The waveform data type is defined only for Labview.
If you want you can create a struct like a waveform. It contains an array and timing information.
However follow this discussion
Message Edited by DaBenny on 26-10-2009 09:36 AM
D. Beninato
(3,264 Views)
