Multifunction DAQ
water level inspection system
I would like to implement a water level inspection system, but i want to produce a hardware too...
Anybodys who got this kind of experiences, please share with me...
I will appreciate all of your guidances. Looks forward your reply eagerly.
Thank you very much.
(3,352 Views)
Range?
Resolution?
Price?
Drift?
Aging?
Monitoring a water tank level under pressure ?
EX class?
There are many many  of systems with various principles on the market, each for their specific use.
At home for rain water tank you can build a DIY capacitive sensor with twisted pair cable and a 555 timer
on the other end are EX class sensors for industrial use...
What do you need?
Greetings from Germany
Henrik
LV since v3.1
(3,348 Views)
I just want to produce a simple prototype for measure the water height with range (0-20 cm), only water, not other liquid...
Can u please suggest me which kind of sensor is better? because i hav never done this before....and also still learning LABview...so I dun know which is suitable...
(3,340 Views)
Accepted by topic author kelvin tay
Very simple: Use the level control of a toilet reservoir and add a potentiometer, ok only use the potentiometer (it`s wise to use a more protected one 😉 and replace the knob with a peace of aluminum with an old tennisball at the end. Use the potentiometer (10kOhm) as a voltage divider (one leg(CW) to AGND, CCW at Vcc(5V) and the tap to Analog in)
If the water level is regularly down, take a look at the way modern laundry appliances use: they use a pressure sensor with an air filled tube.
Very nice is a absolute pressure sensor suitable to be dropped into the water.
However: Water and electricity don't mix well, so take care what you do. If humans can touch the water, all devices have to meet strict isolation classes. Normally the inputs of a PC card don't meet them!
Henrik
LV since v3.1
(3,324 Views)
