07-12-2007 06:35 AM
07-13-2007
11:07 AM
- last edited on
10-02-2025
03:04 PM
by
Content Cleaner
Hello Erkan,
I'm a little confused about your issue. Are you saying that there is always a 5.48V offset on your measurements or that every measurement registers 5.48V? What does your system read before the impact when there is no pressure on your device?
The maximum input range for the NI USB-9233 is +/-5 V. If your measurement is outside this range it may be coerced down to 5 V by LabVIEW SignalExpress. Regarding your questions about using LabVIEW SignalExpress, I would direct you to the Getting Started with LabVIEW SignalExpress manual here, as well as two tutorials.
