Multifunction DAQ
usb 6009 - Driver problems
I using a USB 6009 with LV 7.0 and MAX 4.0.0.3010 and it work right on my dek PC With W XP SP2. I made a VI in LV and aquire ok.
Then I made an appication and made a executable and install it in a laptop under Vista and the vi works right but do not aquire any value.
I go to max and when I hit the test panels shows an error called 50256.
I understand that there are a mistake with the firmware NI-DAQmx and NI-daqmx base.
Could you explain me about this problem and how can I solve it?
Thank you
Ariel Medina
CONIMED SA
arielmedina61@yahoo.com.ar
(4,337 Views)
What version of DAQmx did you install?
For Vista you need at least v8.5, see here:
http://www.ni.com/support/daq/versions_portable.htm#du
Message Edited by AnalogKid2DigitalMan on 10-10-2007 11:44 AM
(4,329 Views)
Ok  I will try download v8.5 from this page.
Thank you for your post AnalogK !
Ariel
(4,321 Views)
With his new NI Daq 8.5 and vista the daq works ok!
I have a new question about this usb 6009 daq card.
Is possible use a pseudo "autoranging input"  in its phisical channels. I will explain about this:
I am measuring a voltage signal that varies from +/- 20 mV to  +/-  20 V. If I configure the input voltage at +/-  20 V, when the input is about 20mV , the resolution is too poor. Is there any  in daq tool that choose the best input range according to the signal amplitude?
Ariel
(4,237 Views)
