04-04-2008 05:10 PM
04-07-2008 11:21 AM
Hi dbeerer,
Thanks for posting to the NI discussion forums. I have a couple of follow-up questions for you, and a suggestion for a next step.
Questions:
Suggested Step:
It sounds like you have taken the right steps to troubleshoot your card. Based on your description, and after looking at the results of the DAQ diagnostic utility that you ran, it appears that your card may need to be sent to NI for repair. The fastest way for you to get this issue resolved (especially if a repair is needed) is to go to ni.com/support and request to speak to an NI engineer. They would be happy to help you finish troubleshooting and process a repair if needed. We will do our best to provide suggestions and help through the forum, but if a repair is needed you will need to contact NI directly.
04-07-2008 12:36 PM
J_Thomas,
Thanks for the reply. I am using NI-DAQ v7.5 in my current computer. I've tried both DAQmx and traditional DAQ and both give me the same troubled result.
When I ran the diagnostics, I had physically disconnected my card to any hardware.
The same computers (with same drivers) work fine with the 6036E card.
I'm a new grad student at my lab where I'm trying to run this hardware and the card has been around before me, so I don't know for sure when was the last time it had worked properly. I'm assuming it did at some point, because the 6071E card was already installed in one of the computers, but the card hasn't responded since I've been working with it.
I'll try the ni support site.
Thanks for your help so far
-David
