Multifunction DAQ
trigger out of pci 6713
Hi guys,
I am using PCI 6713 in order to issue out trigger signals from the analogue output card. What i wish to do is stated below:
1. When the beginning of the Waveform has a gradient of 0, a trigger will be sent out to another component. That means when the waveform becomes flat, a trigger will be sent out.
The waveform is attached below. Can someone give me some guidance on which VIs that i can use to achieve this?
Best Regards
Ridawn
Message 1 of 1
(2,770 Views)
