Multifunction DAQ
trigger config, retrigger
Dear Sir/Madam:
I have PCMCIA NI-DAQ 6715 Card and i generate signal with 50 Hz frequency. I want to synchronize this signal with the mains voltage. I use PFI0 pin for the start trigger. It's works good, but i want want to retrigger my analog output continuously. I working with the LabView Programm (please see attachment). If I retrigger (I use AO Start in While Loop), I have problem with my signal. The signal is no more continuously (about 30 ms i don't have any signal). Is there any other method I can use to get continuosly signal?
Many Thanks
(3,032 Views)
Hi General2,
I think the problem is that you are using the VIs in the wrong order.
Please look at the following VI located in the Example finder:
Open LabVIEW, click Help -> Search Examples...
Signalmeasurement - and acquisition with Hardware -> Traditional DAQ-Driver -> Analog Output -> Cont Generation - E-series D-Trig.vi
In this VI you can see how to create a continuous generation triggered by a digital trigger.
I hope this can help.
Best Regards,
 Andreas Pistek
Message Edited by Andi P on 07-04-2006 11:37 AM
~~~ Logic is a systematic method of coming to the wrong conclusion with confidence ~~~
(3,005 Views)
