Multifunction DAQ
traditional nidaq 6.9.3 with mfc
Is it possible to interface the functions of tradtional nidaq 6.9.3 with a GUI app using MFC? I have to use 6.9.3 since I am working with a daqpad-1200. All the examples use a win32 console application and I was able to get them to work using that method but I get link errors when I try to use them in an MFC application. Or, is it possible to communicate between a console app and an MFC app other than using a common file?
Any insight would be appreciated.
Greg
(3,195 Views)
Hi Greg,
It is possible to use Traditional DAQ with Microsoft Foundation Classes (MFC). The Knowledge Base Document 317742FQ: Programming NI-DAQ in Visual C++ .NET is a great resource on this topic.
To solve your link error, I would try adding the Traditional DAQ libraries to the Linker Properties of the project. These libraries can be found in the default location of C:\Program Files\National Instruments\NI-DAQ\Lib.
If this does not resolve the issue, could you post back with the specific error numbers and text of the link error you receive? Best of luck.
Mallori M.
Mallori M
Sr Group Manager, Education Services
ni.com/training
(3,180 Views)
I'm using visual c++ 6.0. I made sure that the directories you mention were set up in the directories tab under options for the library and include files. I put "#include nidaq.h" and "#include nidaqex.h" in my *Dlg.cpp file, as well as calling DIG_Prt_Config and DIG_Out_Port in the OnInitDialog function. When I compile and link I get the error messages:
   error: LNK2001: unresolved external symbol _DIG_Out_Port@12
   error: LNK2001: unresolved external symbol _DIG_Prt_Config@16
Thanks for the help,
Greg
(3,174 Views)
I just fixed my problems through lookiing through the forum. In addition to putting pathnames into Options/Directories/Include files and library files I had to under Project/Settings/Link/Object/library modules put in "nidaq32.lib".
(3,160 Views)
