Multifunction DAQ
software triggered measurement of voltage, possible?
Hello
I need to measurement a voltage at different positions of a sample. The sytem scans above the sample surface, each time a position is reached I want to start a measurement.
Currently I'm using this procedure, but it's very slow
Initialisation before the measurement:
  • DAQmxCreateTask
  • DAQmxCreateAIVoltageChan
  • DAQmxCfgSampClkTiming
At each point of the measurement
  • DAQmxReadAnalogF64     (this command needs about 95 milliseconds => 5 hours for 300 x 300 pixels)
Any idea how I can get this faster? Maybe using a trigger?
Thanks for any comment!!!
(2,901 Views)
Hello Stephan,
when you got any digital Signal available that gives you a digital Pulse when the Sample Position is reached, you can use this Signal as a Clock Signal for your Aquisition. You then would use a Buffered Aquisition witch would lower the Overhead created by "On Demand" Sampling.
For further discussion the following Information would be useful:
-What DAQ Device do you use?
-What Driver do you use?
-What Developement Enviroment do you use?
Regards!
Moritz M.
(2,881 Views)
