Multifunction DAQ
sine wave with flicker
I try to get sine wave from the waveform generator.
But May I know is there any tools or block that can generate flicker in sine wave ?
Hope for guidance. thank you.
(3,851 Views)
Your sine is an array of numbers, so to add 'flicker' (BTW what do you mean with 'flicker'?) you can add or multiply any other signal to this array......
Flicker in power grids is a amplidute modulation....
XR2206 flicker is a small glitch on the top of the sine ....
Greetings from Germany
Henrik
LV since v3.1
(3,845 Views)
Thanks henrick
Can you show me some examples on how to add or multiply the signal.
The flicker here is refer to the voltage fluctuation from the power system.
HOpe for more help. Thanks.
(3,823 Views)
Here a BD:
and the result:
5 min in the coffee break 🙂
Instead of repainting, try to learn about waveform datatype and try to program a math aproach 😄
Henrik
LV since v3.1
(3,815 Views)
