Multifunction DAQ
simulate signal under 10 hz
hello,
I wanted to simulate a square signal with a frequency of 4 hz. It seems that under 10 Hz, the signal is erratic and much too fast.
It worked when I entered 0.04 as an entry for the frequency, but I do not feel very confortable with this solution...
Message Edited by thrawny on 10-02-2009 03:55 AM
(3,066 Views)
Shown below is the code for a simulated 4 Hz signal. The output is neither erratic or too fast. Simulation implies that you are not using any hardware so what are you using to determine what the signal looks like?
Why don't you post your code or at least an image of how you are doing the simulation.
(3,051 Views)
