Multifunction DAQ
signalexpress generate voltage with PXI 6704
I want to generate a voltage output using signalexpress with PXI6704
first in the task of the signalexpress I create a new task,
Add Step->Generate signals->DAQmx Generate->analog output->Voltage
then choose one channel of ao_0->OK
an error appeared "miss inout"
details is as following:
One or more of the inputs to this step are not selected.  Insert a step before this step which has an output that matches the type of signal this step requires.
how to solve this problem?
 can you introduce some documents to start the using?
thanks
I just buy the signalexpress one week,
it is a little different to start.
can you give some
(2,916 Views)
I only want to generate a DC voltage signal!
(2,915 Views)
