Multifunction DAQ
scope config setup (tds8k)
#1. I am trying to set the scope so that the scope will execute the following;
'auto set' (button)
'clear data'
'condition' (16 number of acquisitions)
current VI displays the waveform in M1 (where M1=C1-C2) channel for about 2 seconds and the scope screen does not show anything at all.
#2. External Attenuation
I have placed 6dB pads on channel 1 &2, but external attenuation VI outputs 15.56dB...I think there must be an internal error with conversion from 6 linear vs. 6 dB...any thought??
(3,037 Views)
Hi jjlee,
I found the instrument driver for the TDS 8000 on our Instrument Driver Network.  I appears that this driver is actually maintained and supported by Tektronix.
It's possible that another user in our discussion forum has experience with this device.  You might try posting in the Instrument Control forum to see if any one there can help.
(3,023 Views)
Hi Michael C,
I will try to copy this posting to the suggested board.
JJ
(3,013 Views)
