Multifunction DAQ
scaling analog input signals
I have a SC-2345 on an PCI-6221 M-Series Board equiped with a SCC-CI20 Current Input Module.
I expirienced a strange behavior:
       When I use the physical channel of the sc-2345 when creating a Global Virtual Channel I get only a sine wave as signal (looks like nothing connected´).
       When I use the physical channel of the PCI-6221 and configuring it as a current input I get the correct readings.
Second problem:
      How can I configure a scale which transforms a 4-20mA Signal into 55-75mm Output?
Thank you in advance for your help
Peter
(3,509 Views)
Hi Peter!
Have you tried using the test panels on Measurement and Automation Explorer instead? You can right click on the SCC-CI1 module and go to Test Panels. This should provide you with another avenue to test your board.
You can scale your input voltage by applying a NI-DAQmx Scale. If you look at this tutorial, it has a section on creating an analog input task and it also shows you how to apply a scale to your task.
Please let me know if this helps.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,498 Views)
