Multifunction DAQ
rtsi trigger delay
I'm doing a synchronized test with two PXI-6115 cards.  I'm sharing an external clock and an external trigger using rtsi lines.  I input the same analog signal into both cards.  I have tested different DAQmx configurations and I will often see the two cards trigger at different times.
My solution is to use Frame 2 in my example, where you tell one card to use the other's StartTrigger.
In Frames 1 and 3, what is causing the cards to skip trigger pulses?  Is it software?  Is there a way to do this other than Frame 2?
Equipment:
PXI-1006 chassis
PXI-8187 controller
PXI-6115
Labview 8
External clock = 5MHz
External trig = pulse every 50 clock cycles
(2,993 Views)
(2,991 Views)
