Multifunction DAQ
read analog inputs - control - write analog output
Hi guys,
I want to read two different analog voltages and based on some calculation, i want to give out an anlog voltage.
Attached you can find my project so far. i can read the two voltages but i have currently problems to give out an analog voltage signal.
So far i just use the analog input signal from channel AI1 as signal for the analog output (instead of the calculations).
But i don't get the desired voltage at the analog output. Can someone help me how to fix this problem?
I am working with
- Labview 2016
- NI USB-6221
Peter
(3,175 Views)
Hello peter2805,
attached a modified vi. An additonal option is to use the AO as on demand software based timed, if you only put out the calculated value.
best regards
Alexander
(3,134 Views)
