Multifunction DAQ
raw data width
I have been using PXI 6251 for a while, and I am changing to PCIe 6361.
I developed visualisation tool for the .tdms files that I want to continue using.
The .tdms files have now a row data width of two instead of 1, and are not readable anymore in my visualisation tool.
How can I solve that?
Configure the PCIe to output data with a width of 1?
A tool to open the file and set it back to 1?
(2,971 Views)
Are you still having this problem? or have you managed to find a solution?
(2,858 Views)
I found a trick by using the two cards with independent tasks, sharing a clock and start trigger. It generates two files with a raw data width of one, which I can actually read to fuse them in a final file with a raw data width of 1.
It seems it's an old-school synchronization
If you have a fancier solution, I would be interested.
(2,856 Views)
