Multifunction DAQ
python Ni daqmx force ,displacement,and strain sine wave signal peak and valley
I am conducting a fatigue test on the structural parts with a fatigue testing machine. I used the NI9189 chassis NI9222 NI9235 NI9237 card to collect the force displacement and strain signal, which is a sine wave signal with noise. How can I analyze the number of sinusoidal cycles and the peak and valley values of each sine wave in real time during the acquisition process
(869 Views)
If you have data of one periode, I would do a sinefit.
Have a look at the python sinetools, should be available from PTB (Bruns/Seeger)  (I'm in the same domain, so I can't tell if these are really public)
If you can lock the timing of your DAQ to the gerenerator the frequency is (should) be known and constant and you can use a 3 parameter sinefit (mag/phase/offset).
Without locking the generator to the DAQ, the frequency is only nearly known and you should use the 4 parameter sine fit (incl also fitting the frequency).
I use LabVIEW, so I can't tell more about the python solution, but can provide some papers on sinefitting if needed. One link I posted here
If the max and min in a distorted sinewave are of more importance and you want to reduce the noise, I would go with a sliding square function fits over about 1/5-1/8(?) of the periode (If a Savitzky-Golay filter is in your python lib, you can (ab)use it for this purpose) and look for min/max. Hint: Result should be better if you apply a something like a hanning window instead of a rectangular one for the fit.
Greetings from Germany
Henrik
LV since v3.1
(831 Views)
