02-13-2010 11:24 PM
I would like to generate a 10V pulse using DAQ 6020E(BNC). This instrument has 2 counters CTR0 and 1, each of which can generate 5V pulse.
I tried to connect them in series but this didnt work because they have common ground.
How do i obtain 10V pulse from the instrument DAQ6020E(BNC)?
Any other way, using DIO etc???
Regards
poli
02-14-2010 12:07 AM
02-15-2010 06:03 PM - edited 02-15-2010 06:11 PM
Hello Poli,
One way to achieve this would be to use an analog output channel to generate the desired voltage (the update rate of the 6020E (20S/s: system dependent) may limit this approach). The community example link included below demonstrates how to use an ao channel to generate a wave with varying frequency/amplitude. (On the front panel, select the Square Wave option).
1. http://decibel.ni.com/content/docs/DOC-7692
Ali M
