Multifunction DAQ
programatically execute or bypass a subvi
Hello
Is it possible to programmatically run or bypass a subVI? I have several subVIs in the main VI. Depending on which of them are selected using the front panel control booleans, I would like to run the selected SubVIs and bypass the rest of SubVIs. How can I achieve this? I have at least 8 of subVIs which can lead to several combinations, so I dont want to use the case structure for running the selected SubVIs.
Your help is highly appreciated,
Regards
Renju Zacharia
(3,077 Views)
Hello Renju,
Can you please elaborate on this.
Because a subVI will not be executed until it receives all its inputs and hence you can program accordingly.
Sahil
(3,056 Views)
Do you want to run the sub VIs in parallel??
Regards
Prashant
(3,050 Views)
