Multifunction DAQ
problems configuring a port as input port in niPXI-6509 board
Hello ,
             I am using a ni PXI-6509 card for my application. Since I have to compile my application in Interval Zero RTX, I am using the static DIO Register level programming using VISA. I have successfully configured the card to do output on  port0. But when I attempt to comfigure another port1(not the same as output) I can successflly configure it. But when I send 5V through the corresponding pins I donot get a value 1 in the Data register for that channel.
the following i did to configure as Input...
1) IO Select register set to 0 (for input as the manual suggests)
2) read from IO data register.
Do I need to do anything special to configure as input port.
please suggest...
Kuchi
(2,962 Views)
(2,945 Views)
