Multifunction DAQ
problem writing to Port A, B, C on PCI-2025E
Thanks for the diagram. This is correct. So if you use the +5V supply on the board to drive the relays, you have up to 1 Amp available. At 10 mA per relay, you will be well below that.
Message 11 of 11
(609 Views)
