Multifunction DAQ
problem with PCI-6023
I have a PCI-6023 and can read a voltage from a strain gauge no problem in MAX test panel, then when I start to use it with LV 7.0 I can read only once. Then it give me a voltage of 10V al the time afer that. When I go back to MAX to test it does not work, it is reading 10V constantly. I also noted that the PCI-6023 shows up in Max under nidaq devices as well as under traditional devices. I would have to restart the PC to get it to work again.
I use LV 7.0 and Win XP on a 1.8Ghz P4 PC with 512Mb Ram.
Willem.
(2,819 Views)
This seems like a software issue. did it ever work? if so, when did it stop working? Which version of the driver do you have? You can check that in MAX under Software.
I would suggest upgrading to latest driver version if you have not yet. I would also suggest running shipping examples to see if the problem occurs still.
(2,803 Views)
