Multifunction DAQ
phase shift
I am acquiring a analog signal, of about 500Hz, using LabView 7.0 and PCI-6221. Now, I need to shift this signal by 90 electrical degrees. How can I do this inside LabView?
Thank you,
Jeferson
(3,623 Views)
A Hilbert Transform will shift it 90 degrees.
Randall Pursley
(3,614 Views)
Randall,
A Hilbert Transform will give a 90 degrees lead, but I need a 90 degrees lag (time delay).
Do you have a hint?
(3,604 Views)
I am assuming that negating the result is not going to give you the right answer.  Then, you can try the inverse Hilbert Transform.
Randall Pursley
(3,598 Views)
