Multifunction DAQ
pci-6023e analog input driver
hi guys
ive recently upgraded my pc.does anyone have a pci-6023e driver?my windows cannot detect the device properly
thanks
Message 1 of 9
(7,377 Views)
You can download the latest and compatible version of device drivers for this DAQ card from here
Depending on your OS, choose the relevant Device Drivers
Message 2 of 9
(7,364 Views)
hi devchander,
thanks for the valuable info. I'm downloading the driver now and will try out if it can resolve my analog input problem.
however, i got bigger problem where my current digital input module model is AT-DIO-32HS is having ISA connector which i dont have it on my new PC.. (new PC doest have ISA slot). Could anybody advice me the solution?? preferably without any expenditure????
prompt support is highly appreciated
max
Message 3 of 9
(7,339 Views)
Probably not possible
But you could buy ISA-PCI adaptors, which might solve your problem
Message 4 of 9
(7,333 Views)
thanks again dev,
i have struggle to get the PCI / ISA adapter but yet to find them in the market. could you advice any manufacturer whom supply this device? btw, i have also search for the driver (AT-DIO-32HS) but unable to get it from the NI website. pls advice me the URL???
thanks again for the support.
Max
Message 5 of 9
(7,331 Views)
Hi Max,
This Device is supported by Traditional DAQ ( Legacy) device drivers, which you will find here
Note: It is not supported by DAQmx
Well, since I personally have not used such and adaptor, I cannot recommend any manufacturer.
Through a google search for ISA to PCI adaptor will yield a list of vendors for this product. Check out if they would suit your purpose
Dev
Message 6 of 9
(7,329 Views)
Hi Dev,
i've been trying to download the tdaq741.zip file several times but it fail in the midst of the download every times. i dont know how to complete the download. is there any other way to get the file? i'm getting tired with this problem. please advice the solution???
theres only two drivers required.
1. PCI-6023e
2. AT-DIO-32HS
Max
Message 7 of 9
(7,262 Views)
Hello chain_bomb.
I just attempted to download the Traditional DAQ 7.4.1 driver from the National Instruments website and was able to do so.  Is there a firewall on your computer that may be causing the download some problems?  To troubleshoot this, I would recommend trying to download the driver from a different machine. Then, if that attempt is successful, simply buring the driver to a CD will allow you to distribute it to the target PC.
Good luck on your application!
Brian F
Message 8 of 9
(7,239 Views)
Thanks for the support. I've managed to get the modules detected. I will need to configure my system to make it work.
Max
Message 9 of 9
(7,215 Views)
