Multifunction DAQ
output a current signal from DAQ
I am trying to use DAQ 6024E to output current signals. but when i am trying to use DAQ assistant to output a current signal it says "No support devices found". i can produce voltage signals using the analog channels but i want to produce current signals. is it possible ? or my board does not support that ?
(2,491 Views)
Nidal,
The analog output channels on the NI 6024E can only output voltage. Thus, the DAQ Assistant will not let you create a current output virtual channel. In order to output current, you may want to consider using one of the following signal conditioning devices with your NI 6024E:
SCXI-1124 Product Page
SCC-CO20 Product Page
Good luck with your application.
Spencer S.
(2,491 Views)
