Multifunction DAQ
nrse
Dear All,
I'm using the analog inputs in NRSE mode of a PCI-6259 Card to measure the voltage of the elements of a battery, I have built a simple resistive divider to adapt the voltage of the battery to the voltage range of the card, I have connected the AIsense to the ground of the battery and the AIn to the its elements
the probelm that I have found is that when I connect a voltage source to one of the analog input I found a proportional  ( roughly one tenth ) to the subsequent input
i.e. if I apply 10V on AI0, immediatly 1.1V appears on  AI1
I checked the electric circuit and it works right if I don't connect the card
I tried also to change the card setting in RSE mode but with the same problem
do someone know the reasons of this phenomenon?
thanks in advance
Grammofono
(3,428 Views)
This might be due to ghosting
Hope this helps..
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,409 Views)
Dear GovBob
many thanks for your help
I will work on your advise
best wishes
(3,391 Views)
