Multifunction DAQ
ni usb 6008 daq wrong voltage when using test panel
i am trying to do loopback test for my ni usb 6008 daq, following the description in the manual. even though i vary the voltage, i cant get the voltage i chose.. you can see in the picture attached, i set the parameter as 0 to 5v but there is still voltage below 0.
Message 1 of 15
(5,753 Views)
All of the actual physical ranges on the 6008 are bipolar so what you have is normal. Setting the range on the screen tells the driver to pick the closest actual range.
Message 2 of 15
(5,746 Views)
but when i try to build a vi, i cant get the voltage i set for the output. it will still gives the voltage as shown in the pic. the voltage wont change for what ever value chosen
Message 3 of 15
(5,739 Views)
So you are having a problem setting an output? I did not get that from your original post.
Message 4 of 15
(5,733 Views)
What do you have connected to what?  I can't find the setup you are talking about.
What voltage are you trying to output?
My initial guess is that you don't want to have a Differential configuration, you want Referenced Single Ended (RSE).
GCentral
Message 5 of 15
(5,732 Views)
example
the example video above shows how to control the voltage input and shows the output. but i cant replicate the example no matter what i try. it will always shows the voltage like my previous attachment
Message 6 of 15
(5,728 Views)
What video are you talking about?
Message 7 of 15
(5,726 Views)
click on the example. it's a link to the video
Message 8 of 15
(5,720 Views)
the link need to be opened with a flash capable browser.
Message 9 of 15
(5,716 Views)
I'm not going to watch an hour long video to help you figure this out.  I don't have time for that.  So please answer these questions:
How exactly do you have the DAQ wired up?  And don't foget a single wire.
What are you setting the output voltage to?
GCentral
Message 10 of 15
(5,712 Views)
