02-14-2008 01:35 PM
02-20-2008 07:14 PM
Hi ronan35,
I didn’t get errors while running your vi. First, I specified a file path and then ran your vi and I was able to acquire data from a USB-6009 and write the data to a file. Sometimes the errors have an accompanying message that briefly describes them and gives possible reason. Related to the errors that you mentioned, I found some links that can be helpful in troubleshooting them:
- Why Do I Get Error -200279 When Writing Continuously Acquired Data to a File?
- (DAQmx) Error -200279 During a Continuous, Buffered Acquisition
- Common NI-DAQmx Error Codes and Solutions: Codes -200000 to -200299 and -50103
If you can provide me the specific error and what hardware you are using I could be able to help you better. I hope this is helpful,
