Multifunction DAQ
multiple nidaq driver installation
Hi, I am using a PC running NT4 that has the AT-A2150 and the AT-AO-6 cards with NIDAQ version 4.9.0f2.
My problem is this. I am having problems with "buffer underrun" when using WFM_DB_Transfer to generate 3 waveforms on 3 analogue output channels of the AT-AO-6.
I would like to try a newer NIDAQ version to see if there is a problem with the old driver. Unfortunately, the AT-2150 is only supported by NIDAQ 4.9.0f2.
Can multiple installation of NIDAQ drivers exist on the same machine? My application uses both the AT-AO-6 and AT-2150.
(2,844 Views)
Greetings,
Unfortunately, multiple versions of NI-DAQ cannot be installed on a computer at the same time. This will definitely cause problems. I do agree that upgrading your version of NI-DAQ could solve your buffer under-run problems. You may want to install your AT-AO-6 on another computer with a more recent version of NI-DAQ and see if that solves the problem. If it does not, then something else is to blame, and you do not need to worry about the AT-A2150 not being compatible with newer versions of NI-DAQ. If it does, you may want to consider upgrading your AT-A2150. Both the PCI-4452 and PCI-4552 have similar functionality to that of the AT-A2150. Below are links to the product pages for these devices:
NI PCI-4452
NI PCI-4552
Good luck with your application.
Spencer S.
(2,844 Views)
Spencer,
Thanks for the advice. It turns out that the buffer
underrun was a symptom of a problem in another part
of the code. I have reworked the code and it works
fine now.
It would have been great if NIDAQ could
detect buffer underrun with double buffering even if
WFM_DB_Config() was configured without the oldDataStop
parameter set, as I was forced to actually listen to
the received samples to determine if an underrun had
occured. The alternative would have been to restart
the waveform generation which I found to be tricky and
it would still have resulted in several received
samples being repeated or a period of silence on the
receiving end.
Thanks for the info on the suitable replacements for
the AT-A2150. The card will ha
ve to be replaced sooner
or later, and it will be great to be able to use the
same code with the new cards.
Tat
(2,844 Views)
