Multifunction DAQ
multi parameter analysis
I'm looking for a function where multisim changes multiple parameters automatically.
For example like a matrix:
(1, 1, 1)
(2, 1, 1)
(3, 1, 1)
(1, 2, 1)
(1, 3, 1)
etc...
I didn't find anything like that in help or in forums. Only the standard one parameter sweep.
Hope anyone of you can help me!
Looking forward hearing from you.
Greetings
(4,562 Views)
Dear Whfas,
Which parameters do you mean exactly?
Kind Regards,
Oleg Scherling, M.Eng | Applications Engineering | National Instruments | NIG |
(4,522 Views)
thanks for your answer.
These parameters:
AC Source: Voltage
Capacitator: capacity
Resistor: ohmic resistance.
I need to find the best operating point in a circuit so I need to change all these parameters to figure out wich combination is the best.
Hope you can help me! 🙂
Best regards
(4,519 Views)
Dear Whfas,
The only way to make such a Simulation is the "Parameter Sweep Analysis"
Here is a Tutorial how to configure this analyze correctly:
http://www.ni.com/white-paper/12777/en
For your requirement you have to combine 3 Parameter Sweeps!
You have to select List as Sweep variation Type and then du add 2 other Parameter Sweep under More Options -> analysis to sweep and there choose nested sweep and edit his analysis and also the next nested one.
Kind Regards,
(4,509 Views)
Dear Scherling,
I can't find "more Options" where I can add new Parameter Sweeps.
May you uploand a screenshot?
Thanks!
Best regards
(4,474 Views)
Hello Whfas,
you find this here
and then you can make neastet parameter sweeps
You can also use the Monte-Carlo analyses for this.
best regards
Alexander
(4,467 Views)
