Multifunction DAQ
more than 2 analog outputs with daq
Hi All
I have a 6025 card.It has 2 analog outputs.I want to use it to control 3 devices Any ideas?
Regards
(3,074 Views)
Does the 6025 have digital outputs? If so you might be able to setup a simple digital to analog converter.
(3,068 Views)
Yes but how?
In the meantime another idea striked .I ll be using RS232 port.
anyone can suggest me a RS232 to voltage converter module.I have found one but it is bit expensive looking for a cheaper solution
Thanks but digital outputs will again require a DAC .I think this is what you are suggesting.
Tell me about ur idea.
Thanks and Regards
mission_labview
(3,059 Views)
With this method the steps between voltages are going to be large. If you need fine control you might need to buy another daq card. A series of parallel resistors going into a summing op-amp is one idea. If you pick up any decent electronics books it will have DAC.
(3,047 Views)
