Multifunction DAQ
missing dll
Inside the MeasurementStudioVS2003\DotNET\Assemblies\Current folder, the only dll is
NationalInstruments.Common.dll
but  NationalInstruments.DAQmx.dll is missing !!
Why ?
Thank you.
(3,664 Views)
Hello Bip Bip,
Please see the attached document to solve the problem:
Visual Studio .NET Application Missing the NationalInstruments.DAQmx.dll File
Sanaa T
Sanaa T.
National Instruments France
(3,654 Views)
After a lengthy conversation with the support staff at NI, I learned some things that are rather hard to divine...
I wanted the NIDAQmx.dll and its associated header file.
NIDAQmx.dll is really nicaiu.dll and it resides in C:\WINDOWS/System32\nicaiu.dll.
The header file NIDAQmx.h is located at:
C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include
Example code that uses the methods may be found in (of all places):
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\
This post would have helped me when I was looking, so I thought it might help the next person whose trying to use the "loadlibrary" function in Matlab to control their DAQPad-6508.
yours,
Raj
(3,481 Views)
