Multifunction DAQ
max NI daqmx devices list not display
I am using usb 6008 cards connected on PC by usb
problem is MAX menu ( tree on the upper left part of the screen ) doesn't list under "devices and interfaces" the line "NI daqmx devices" as before on a previous program ( we had to change to windows7)
so I am not able anymore to connect differents cards on my PC ( worked well with a previous program , I only had to rename the card in the list to make it work )
on small PC under "systems" there is "software" only , not even pxi devices
thank you for help
(3,581 Views)
Maybe you could try to reinstall or repair the last version of NI-DAQmx 9.4. This is a link which could be useful.
Regards.
(3,568 Views)
+1 for reinstalling MAX.  Seen this happen several times here, reinstalling fixes the problem.
(3,564 Views)
