Multifunction DAQ
lvruntimeeng.msi install error on winxp
Hello all,
 I had a NI-6221 installed on a x86 winxp SP2 along with labview7.1 and DAQmx of the same age.
This pc failed, then I bought a new desktop and installed LabView2010 and all the newer versions of drivers and DAQmx.
However all my old vi stopped to work correctly, because they were made for labview7.1, so I had to uninstall everything (and in a hurry) and reinstall labview7.1 and DAQmx 3.0 (or something).
After a while I noticed that the "test panel" in DAQmx was not working, and I read on the forum that this was due to an incomplete uninstall.
Therefore, I uninstalled everything throught NI application interface.
Then I tried to uninstall the rest with MSIblast, but I've got the error 1772
I have seen the solution at
http://digital.ni.com/public.nsf/allkb/268AD2EDA9B14EFC86256E7F00790156?OpenDocument
and tried to install manually labview7.1 run-time through lvruntimeeng.msi, but it failed, saying that a newer version is present.
Now, LabView2010 is no longer available on the web and I do not have a copy of it.
How can I do to install and then uninstall lvruntimeeng.msi of labview2010 (given that this is the right way to proceed)?
Should I install and uninstall lvruntimeeng.msi of labview2011?
 Alessandro
(6,172 Views)
Hello abigi,
in the following link you can find the Labview 2010 runtime engine.
http://joule.ni.com/nidu/cds/view/p/id/2087/lang/en
Antonios
(6,165 Views)
Thanks! I downloaded the 2010 runtime engine (... pardon me, but I did not expected to be on the NI site and I had not looked for it).
I installed the 2010 runtime engine (actually, although I selected only the runtime engine it installed many applications).
Then I uninstalled everything, but the labview7.1 runtime engine (which is the only application surviving in msiblast) is still giving me the error 1722 and 1603.
And I when I try to reinstall it through the lvruntimeeng.msi, it prompts "a higher version of this product is already installed"..
Am I missing something?
Is there a particular procedure for uninstalling? Do applications need to be uninstall in a specific order? Mumble mumble...
 Alessandro
(6,156 Views)
Hello Alessandro,
can you please complete the following steps?
  • Delete the folders 8.0 and later that are in C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\
  • Run msiblast.exe
  • Delete the following entries
    NI LabVIEW 8.0 FF Run-Time Engine Libs and later (if you have one)
    NI LabVIEW Run-Time Engine 8.0 and later
  • Restart your PC
After I think that you will be able to reinstall LV 7.1 Runtime engine. Can you please try and see if you are able?
Antonios
(6,152 Views)
Sincerely thanks for the reply.
What I tried today was: run MSIblast (removing everything but runtime eng 7.1). remove all National Instrument folders. clean registry entries according to the pdf http://forums.ni.com/ni/attachments/ni/250/34391/2/MSI%20Blast.pdf
Clean again all registry with CCleaner
Clean everything with microsoft install cleaner.
At this point everything seemed to be gone, event the NI installer in the add/remove packages menu.
Then what I did was:
I removed the PCI NI-6221.
I installed Labview 7.1 (no drivers)
I installed DAQmx
I physically installed the NI-6221.
However I am still having the same problem: in MAX the test panel window does not open anymore.
Since I had read on other posts that this might be due to mixed versions and install problems, that's why I wanted to clean and reinstall everything (and then I had problems with the runtime engine).
I was thinking of uninstall/msiblast etc everything again. And reinstall in a different order:
DAQmx
NI-6221
Labview
This might be a solution?
Otherwise I have windows installation cd ready...
Any advice is appreciated. Thanks!
Alessandro
(6,150 Views)
I think I'll go for a HD formatting...
MSIblast cannot uninstall run-time engine even this time; I am getting the same error as before.
I'll go for an annoying HD erase...
Thanks for the help!
Alessandro
(6,146 Views)
