Multifunction DAQ
lock in amplifier reference frequency always 1
I am using the DAQmx lock-in amplifier software that was downloaded from NI and I am using the PXI-NI-4462 DAQ board.  I was testing the software by using two function generators to generate two different sine waves and sampling them with the 4462 on channels 1 and 2.  The issue I am seeing is that the reference frequency is always reported as 1Hz and this never changes with a change of the input reference sine wave.  Is there something I am missing?  Thanks for any help!
Matt
(2,955 Views)
Are you using the NI Lock-In Amplifier Start-Up Kit downloaded from our website? If so, which of the VI's are you using for this example that you are testing as this will help us take a look at the issue? Also a screenshot of the problem that you are seeing would help us to better understand the issue, one for one frequency, and another at the second frequency of input.
Frank,
Software Group Manager
(2,921 Views)
