08-08-2006 12:00 PM
08-10-2006 10:42 AM
Your issue is a well known one, you absolutely need to identify your PXI
chassis, if you don't you'll be able to export your configuration as if it was
ok, but this one will be unreadable (you won't be able to import it).
You must also run "nipxiconfig" before running nidaqmxconfig export.
Here is a link that may really help you configuring your devices :
Hope this help
Richard Keromen
