Multifunction DAQ
interrupt programming on 6254
Hi, I'm writing a card driver using RTX, DDK and the NI PCI-6254,
I've managed to init the card and can read channels fine as long as I enter a loop, i.e.
m = 0
while (!board->AI_Status_1.readAI_FIFO_Empty_St())
        ... read FIFO data
this works perfectly, however, For my particular application I need to use interrupts because the response to an event
has to be very very fast. the problem i'm having is I can register the interrupt on the correct pin, however cannot get the
card to generate any interrupts. the provided examples by NI don't have any that use interrupts.
Does anyone know how to set up the registers for FIFO_NotEmpty interrupts on an M Series card?
John
(3,182 Views)
sorry, ive posted it in the wrong section again!!!
(3,181 Views)
Re-entered here :
http://forums.ni.com/ni/board/message?board.id=90&message.id=286
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,167 Views)
