Multifunction DAQ
installing daqmx on opensuse
I need to install daqmx on Open Suse 11. I found this post which suggests to start with the kernel source:
http://forums.ni.com/ni/board/message?board.id=170&message.id=265660&query.id=179228#M265660
However, I cannot find the kernel source! Where is it located? This is our kernel:
 > uname -r
2.6.25.11-0.1-default
Thanks in advance.
(3,176 Views)
Hi dotancohen,
You may want to check /usr/src/linux. The best way to find it may be to just do a search.
Kent
(3,157 Views)
Thank you, tnek. I will check there.
(3,148 Views)
