07-28-2015 10:07 AM
Well it should be straightforward to rename a simulated cDAQ in MAX - right click on the simulated device in the navigation pane and select rename. However, when I try this it just keeps reverting back to the original automatically defined name. I've tried editing the "hostname" dialogue box as well, but that also just reverts back. I don't get any error message, and the simulated device is created just fine in the first place. I'm using MAX 14.0, LV 2014 etc from NI Developer Suite 2014 DS2.
- Am I only allowed to rename the numeric part of the name e.g. "cDAQ1" to "cDAQ2" ?
- Is there something else I need to do - e.g. restart MAX - to see the change ?
- I presume since I am simulating an Ethernet cDAQ that it appears under the "Network Devices" - is there a restriction on renaming for Network Devices ?
- Could a stopped NI service be responsible ? I've got NI Citadel services stopped since something was making them slow my PC down unacceptably.
Of course I've tried some of the above. Surely this should be straightforward, so I expect something is broken, but I'm not 100% sure if there is some unusual feature I am missing here.
Thank you,
Andy
08-04-2015
04:52 AM
- last edited on
11-21-2025
01:58 PM
by
Content Cleaner
Hi AndyClegg,
My name is Mitchell Goon, from National Instruments Technical Support.
With regards to your queries:
You may wish to refer to “Configuring and Renaming DAQ Devices” under the Help section in MAX.
Additionally, you may wish to refer to the following link, which may be useful in improving performance when using Citadel:
http://digital.ni.com/public.nsf/allkb/69F4CD6590F5DFDC86257B090050495F
I hope that this is the information you were looking for. If this is not the case, please do not hesitate to contact us and we would be more than happy to assist you.
Kind Regards,
Mitchell Goon
Applications Engineering
