11-24-2008
05:11 PM
- last edited on
05-07-2025
02:53 PM
by
Content Cleaner
I perform retriggerable data acquisition based on technique described here and as my starting point couple year ago I used attached example shipped with LabVIEW.
What I would like to achieve now is to generate another trigger with some delay in parallel with data aquisition when the original trigger arrives.
To make a simple schema:
Trigger is recognized->DAQ [that works perfect already more than one year]
->wait 100ms->output the trigger [has to be added]
Using WXP, NI PCI 6110
Thank in advance to anybody interested
12-02-2008 10:05 AM
Hello, I was maybe thinking that the way to go would be to produce a pulse on one of the digital outputs when the trigger is recognized. But how to delay the pulse on the hardware level? I could do that by software by since the triggers come with high rate it won't be reliable. Is there a way to program the DAQ card to do that?
Thanks!!!
