Multifunction DAQ
how to connect ysb 6259 with pin detector et-2000
I have to connect 6259 with detector to get the power , and I want it to show in labview ,  so I set the daq assistant in voltage , like picture , but get error , only use  "analog input 1 " on 6259
How should I connect these two ? thank you
(3,326 Views)
Can you attach your LabVIEW code here?
It might be the structure of your code goes wrong.
(3,296 Views)
