Multifunction DAQ
how to acquire digital input of pci6024e
Hi, I'm newbie in daq with e series. I'm using LV8. I dont know why the card can not acquire my signal. My signal come from signal generator (for testing purpose). I'm using the example .vi file which I found in the net. Here I attach the example. Hope someone could tell me what is the problem and guide me at least I can acquire the signal.
Thank you.
(3,157 Views)
Where did you find that and why don't you start with the examples that come with LabVIEW?
You are attempting analog input and not digital input. That VI is written a bit strangely since it is set for continuous acquisition but then the DAQmx Read is set for 1 point. Try one of the simple examples of analog acquisition and if you have a problem, please provide some details - especially any error codes that are generated. You could also use the DAQ Assistant.
(3,148 Views)
You can find digital input example from Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Digital Measurement.
Check with Requirement pane inside Example Finder whether this example supports 6024E.
(3,139 Views)
thanks to all.. First, I'll try wit example as suggested.
(3,125 Views)
